Article ID : 00186907 / Last Modified : 30/12/2019
Connect your Android TV to the Amazon Alexa App
    To connect your Android TV to the Amazon Alexa App, please use the following steps:
    1. On your supplied remote control, press the HOME button.
    2. Scroll down to Apps.
    3. Under Apps, locate TV Control Setup with Amazon Alexa.
    4. Select the TV Control Setup with Amazon Alexa app.
      NOTE: If your TV is not supported, TV Control Setup with Amazon Alexa app will not appear in the apps list.
      Please check Applicable Products and Categories of This Article for supported model information.
      Amazon Alexa home card
    5. At the initial setup screen, click Next to continue. Then, follow the on-screen instructions to complete the setup.
      Initial setup
    6. Agree to the Privacy Policy and go to the next screen.
      Privacy Policy
    7. Under the Log in with Google screen, select Next.
    8. Choose your Google account and go to the next step.
      NOTE: If Google account is not registered on the TV, please register a Google account.
    9. Choose an easy-to-say TV name.
      NOTE: Pick from the list or create your own TV name.
    10. Complete the three last steps
      1. On your phone, enable the Android TV skill in the Alexa app.
        NOTE: When Android TV skill on Amazon Alexa app is already enabled, say “Alexa, discover my devices” and skip to Step 11.
      2. Link your accounts by entering the same Google account as you chose in Step 8.
      3. Ask Alexa to discover your devices.
    11. On your TV, select Done to exit from the setup. Otherwise, ask Alexa to try the other functions available.
      Setup complete
