Article ID : 00174053 / Last Modified : 03/04/2017
How to use the timer function on your TV
    What is the on timer function?
    The on timer allows you to let the TV turn on automatically at a specified time. You can use this function to:
    • Let the TV turn automatically on when your favorite shows comes on
    • Use your TV as an alarm clock
    How to set the on timer function?
    1. Press the HOME button on the remote.
    2. Select the Timers in the Settings category.
    3. Select the Timer / On timer.
    4. Set to On (or check On timer) in the On timer category.
    5. Set each item with the arrows and ENTER buttons on the remote.
    On time function settings
     Selection item  Description of the item
    On timer When you select (or check) On, you can set the following items, and the TV turns on automatically at the time you set.
    Day
    Select a day of the week from the following.
    • Every day
    • Every Mon-Fri
    • Sunday
    • Monday
    • Tuesday
    • Wednesday
    • Thursday
    • Friday
    • Saturday
    • Every Sunday
    • Every Monday
    • Every Tuesday
    • Every Wednesday
    • Every Thursday
    • Every Friday
    • Every Saturday
    Time Sets the time.
    Duration The TV automatically turns off after the following set time passed (power standby):
    You can set 1 hour to 23 hours.
    Input Select the broadcast or the input source
    Channel When you select Broadcast, you can select the desired Channel.
    Volume setup Adjusts the volume of the TV speaker.
