Article ID : 00124699 / Last Modified : 22/02/2021
My Android TV can't play back content stored on my home network server
    Your Android™ TV can't play films, videos, images, or audio files stored on your home network server if the file's codec is unsupported and you are connected through a proxy.
    To play back files stored on your home network server, it is necessary to establish a connection between the Android TV and the server.
    • Make sure that your TV supports the codec of the files you want to play. For supported codecs, check your TV Help guide.
    • Make sure that your TV isn't connected to a proxy server. Depending on your TV's software version, disable the Proxy settings.
    Adjust the Network settings
    BRAVIA TV-side setup
    1. Using the supplied remote control, press the HOME button.
    2. Select  Settings.
    3. Select Network in the NETWORK & ACCESSORIES category.
    4. Select Home network setup.
    5. Select Server diagnostics.
    6. Select Yes.
    • NOTE: The "Servers could not be found" message will be displayed if devices are not connected.
    Server-side setup
    • Refer to the instruction manual of your server equipment to connect it to the home network.
    Disable the Proxy settings
    If a proxy is set, the contents of the home network cannot be played. Follow the steps below to disable the Proxy settings
    For Android™ 7.0 (Nougat) or later
    2. Select  Settings.
    4. Select Network setup.
    5. Select Expert.
      • If you're using a wired LAN, select Proxy settings in the Wired LAN category.
      • If you're using a wireless LAN, select SSID in Available networks, then select Proxy settings.
    6. Select NONE.
    For Android 6.0 (Marshmallow) or earlier
    2. Select Settings.
    5. Select Expert.
      • If you're using a wired LAN, select Wired LAN.
      • If you're using a wireless LAN, select Wi-Fi and select SSID.
    6. Select Advanced options.
    7. Select Proxy settings.
    8. Select NONE.
    NOTE: For steps to connect your server to your network, check its manual or contact the manufacturer for further assistance. Manuals are posted on our support website.
    *Android, Android TV are trademarks of Google LLC.
