Article ID : 00138976 / Last Modified : 17/05/2019
Types of 4K (50p/60p) video signals supported by the TV
    Depending on the TV that you use, the supported types of video signals will be different. See below.
    For Android TV
    Resolution/frequency 8bit 10bit 12bit
    3840@24 Hz YCbCr 4:2:2
    YCbCr 4:4:4
    RGB
    YCbCr 4:2:2
    YCbCr 4:4:4
    RGB
    YCbCr 4:2:2
    YCbCr 4:4:4
    RGB
    3840@25 Hz
    3840@30 Hz
    4096@24 Hz
    4096@25 Hz
    4096@30 Hz
    3840@50 Hz YCbCr 4:2:0
    YCbCr 4:2:2*
    YCbCr 4:4:4*
    RGB*
    YCbCr 4:2:0*  -
    3840@60 Hz YCbCr 4:2:2* YCbCr 4:2:2*
    4096@50 Hz  -  -
    4096@60 Hz  -  -
    Red: For 2015 models, please update the software.
    *: Enhanced format
    2014 BRAVIA
    YCbCr 4:4:4
    RGB
    YCbCr 4:2:2 YCbCr 4:2:2
    3840@25 Hz
    3840@30 Hz
    4096@24 Hz
    4096@25 Hz
    4096@30 Hz
    3840@50 Hz YCbCr 4:2:0  -  -
    3840@60 Hz
    4096@50 Hz
    4096@60 Hz
