How to set up and use the Wi-Fi Direct feature for 2014 TV models
To set up and use the Wi-Fi Direct feature, follow the steps below.
Enable the Built-in Wi-Fi setting on your TV.
- On the supplied remote control, press the HOME button.
- Select Settings.
NOTE: The image below is an example of the 2014 TV model. - Select System Settings or Network.
NOTE: If the TV shows Network, skip to step 6.
- Select Setup.
- Select Wi-Fi Setup.
- Select Built-in Wi-Fi or Built-in Wireless LAN.
- Select ON.
Turn on the Wi-Fi Direct setting of the TV.
- Select Settings.
- Select Setup.
- Select Wi-Fi Direct.
- Select ON.
Display the WPA key of the TV.
- Select Settings.
- Select Setup.
- Select Wi-Fi Direct Settings.
- Press the Options button.
- Select Manual.
- Select Other Method.
NOTE: The SSID and the WPA key will be displayed on the TV screen.
- On the Wi-Fi setting of the Wi-Fi Direct device, select the SSID of the TV and enter the WPA key displayed on the TV screen as the password.
NOTE:
- For more details refer to the manual supplied with your smartphone or tablet.
- For instructions on using the Throw function to transmit images or music from an Xperia, see the FAQ below.
How to transmit images and music from an Xperia to the BRAVIA TV via Throw.
