Article ID : 00236586 / Last Modified : 04/12/2020
My Bluetooth remote does not work properly after connecting a DUALSHOCK4 controller via Bluetooth
Can't control TV by Bluetooth remote control. It takes time to operate the Bluetooth remote control. Can't unpair and disconnect DUALSHOCK4.
    IMPORTANT:
    • This article only applies to specific products and/or operating systems. Please check the Applicable Products and Categories section of this article.
    • Due to the PlayStation Now service ending, all DUALSHOCK controllers are no longer supported.
      For details, refer to: How to connect the DUALSHOCK4 to an Android TV™
    If you have connected DUALSHOCK4 to the TV via Bluetooth, unplug the TV power plug, plug it back in, and then unpair DUALSHOCK4 as follows:
    1. Press the HOME button on the remote control.
    2. Select Settings image Settings.
    3. The next steps will depend on your TV menu options:
      • Select Remotes & AccessoriesBluetooth settingsWireless ControllerUnpairOK. (Android™ 9 Pie)
      • Select Bluetooth settingsWireless ControllerUnpairOK. (Android™ 8.0 Oreo™ or earlier)
