Your wireless speaker doesn't support deleting just one set of pairing information. Initialize your speaker to delete all pairing information. Select your speaker model, turn it on (except for CAS-1), and then follow the instructions provided to initialize the speaker.
- Initializing the speaker resets the device to factory default settings, which deletes all network settings and pairing information.
- Depending on the model, it may enter the standby mode after initializing the wireless speaker.
CAS-1
- Turn off your speaker.
- Press and hold the
(on/standby) button for over ten seconds while the device is turned off.
- The LED status indicators will flash quickly.
GTK-XB60 or GTK-XB90
Press and hold the FUNCTION
PAIRING button and VOLUME - button simultaneously for more than five seconds.
LF-S50G
Press and hold the
(microphone off) button until all four status LEDs light in orange.
LSPX-S1
Press and hold the
(volume) - button and the on/standby (power) button simultaneously for five seconds.
SRS-X1
Press and hold the
(previous) button, the
(power)
PAIRING button, and the VOL + button simultaneously for more than five seconds.
SRS-X9, SRS-X7, SRS-X99, SRS-X88, or SRS-X77
Tap and hold the VOL - button and the ON/STANDBY button simultaneously for more than five seconds.
SRS-XB3, or SRS-XB2
Press and hold the
(power) button and the VOLUME - button simultaneously for more than five seconds.
SRS-X11
Press and hold the
(power) button, the VOL - button, and the VOL + button simultaneously for more than five seconds.
SRS-BTD70
Press and hold the VOLUME - button and the INPUT/PAIRING button simultaneously for more than five seconds.
SRS-HG10
Press and hold the + volume button and the SET UP button simultaneously for more than five seconds.
SRS-ZR7, SRS-ZR5, SRS-XB41, SRS-XB40, SRS-XB31, SRS-XB30, SRS-XB21, SRS-XB20, SRS-XB10, or SRS-HG1
Press and hold the Volume - button and the
(power) /
