Article ID : 00230244 / Last Modified : 03/02/2022
Cannot connect the TV and Sound Bar using Bluetooth. (HT-S100F/SF150)
    This may occur if the Bluetooth function of your HT-S100F soundbar is off. To turn it on, press and hold the Power(power), Input(input select), and (volume) buttons on the soundbar at the same time for more than ten seconds.
    Note: The USB indicator flashes twice when Bluetooth is on. If it's off, the USB indicator flashes once.
    If the issue still occurs, follow these steps to reset your soundbar:
    1. Press and hold the Power(power), Input(input select), and + (volume) buttons at the same time for more than five seconds.
      • All indicators on your soundbar will flash three times.
    2. Unplug the power cord and plug it back into a working outlet.
    3. Turn on your soundbar.
