Article ID : 00197553 / Last Modified : 03/02/2022
How to listen to TV audio from my Sound Bar only.
TV audio comes out of both the TV speakers and Sound Bar.
    The sound normally comes from the TV speakers and the soundbar if they are connected with an HDMI cable. Follow the steps below to output sound from the Soundbar only. Make sure to check the sound after every step. If you need model-specific information, check the supplied manual.
    1. On your Soundbar, make sure the Control for HDMI function is on.
    2. Turn the TV and Sound bar on and off.
    3. Reset the Sound bar to the default settings.
