Article ID : 00151349 / Last Modified : 12/07/2022
TV sound is not heard from the Sound Bar, Home theater or Home audio system
No sound or very low sound is heard from the wireless subwoofer or surround speaker.
    IMPORTANT:
    • This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article before starting these steps.
    • If there is no sound output from the Sound Bar subwoofer, refer to the No sound is output from the Subwoofer article.
    Follow these steps to troubleshoot the issue:
    NOTE: Depending on the model, names and operations may vary, or certain settings may be unavailable. For details, refer to the manual of your TV or audio device.
    1. While your TV and audio device (Sound Bar, Home Theater System, or Home Audio System) are off, verify that the cables between the TV and Audio device are securely connected.
      NOTE: Disconnect the HDMI cables, then reconnect them again.
    2. Make sure that your TV has an ARC or eARC/ARC label on the HDMI jack.
      When the TV has an HDMI (ARC or eARC/ARC) label on the HDMI jack (HDMI IN)
      1. Connect one end of the HDMI cable to the HDMI IN (ARC or eARC) jack on the TV.
      2. Connect the other end of the HDMI cable to the HDMI OUT jack on the Audio device.
      Show connection diagram
      When the TV has no HDMI ARC label on the HDMI jack
      1. Connect one end of the HDMI cable to any HDMI IN jack on the TV.
      2. Connect the other end of the HDMI cable to the HDMI OUT audio device.
      3. Connect an optical audio cable from the TV's optical digital audio out to the OPTICAL IN on your audio device. If you can't connect with an Optical Digital cable, use an Audio Analog cable instead.
    3. Verify that your TV's audio output setting is set to an audio device, and on the TV, change the audio output destination setting from TV Speakers to Audio System.
      NOTE: Just connecting the TV and audio system with a cable will not produce sound from the audio system.
    4. Make sure that the Control for HDMI of your TV and audio device is set to ON.
      NOTE: If your TV is BRAVIA, set the Control for HDMI (BRAVIA Sync) to ON.
    5. In the HDMI settings for your audio device, set the Audio Return Channel (ARC) or TV audio input mode to ON or AUTO.
      NOTE: Depending on the model, the setting name may vary, or it may be unavailable. For details, refer to the manual of your audio device.
    6. If the audio system's input mode is set to other than TV, or the Home menu is displayed, the sound is not output. Press the INPUT or TV button on the audio device's remote, then set the input mode to TV.
    7. Turn on the TV, then your audio device.
    8. Change the TV audio output setting to PCM and check whether the sound is output. If the audio device connected to the TV does not support compressed audio, sound may not be output depending on the type of broadcast or video. Check your TV manual for more details.
    9. If you have a BRAVIA TV, update the TV software to the latest version.
      For how to update your TV, refer to the How to perform a software update article.
    10. Update your audio device software to the latest version.
      To update your audio device, visit the Sony Support website, search for your audio device by entering the model name, and then go to the Downloads section.
    11. Reset the audio device and the TV.
      For how to perform a reset, refer to the manual of your device.
