Applicable Model
This information is for the following models:
  • AXS-AR1
  • AXS-AR3
  • AXS-CR1
■AXSM Drive Utility
This software utility includes several functions for use with the AXS Memory Card Reader (AXS-CR1 and AXS-AR1/AR3).
Displaying the status of an AXS-CR1 and AXS-AR1/AR3 drive and AXS Memory Card
Fully formatting an AXS Memory Card
Retrieving log data from an AXS Memory Card
Updating the Firmware of AXS Memory Card
Recovering the corrupted Clip-file of AXS Memory Card and PC
■AXSM Drive Utility 3.3.0 Update
Support recovery of the clip recorded with VENICE 2 V3.0
Support for Mac application ‘Parashoot’ manufactured by OTTOMATIC
Fixed a minor bug on the Mac version GUI
Support macOS Sonoma 14.2
Note) When installing on the Mac with Apple Silicon, it is necessary to change the Security Policy setting. See release note for the details.
■Supported OS
Windows 10 64bit,Windows 11 64bit
macOS Sonoma 14.2,macOS Ventura 13.6.2,macOS Monterey 12.7.1
■Note
"Recovering Clip" function is available for the corrupted Clip-files created on AXS-R5 firmware version 2.00 and later.
If an older version of AXSM Drive Utility is installed on Windows PC, please uninstall, restart the PC and then install the new version.
When using an AXS-CR1 Memory Card Reader with a PC running the Windows 7® Operating System, it is recommended to install the Windows 7 update program released by Microsoft®. Using AXSM Drive Utility Version 1.1 or later and a fully updated version of Windows 7 in combination, data transfer speed from the AXS-CR1 is improved.
For details, refer to the Release Notes.
■Support
Click here for technical support on this product.
https://www.sonycreativesoftware.com/axsmdrive?lang=ENU
