Applicable Model
This information is for the following models:
  • SDM-F27M30
About this download
Benefits and Improvements
  • Improves automatic input selection speed
  • Improves general performance of the monitor
Preparation
You can update the software of the monitor using a Windows computer. The software cannot be updated using other operating systems.
Note: In order to perform the software update properly, connect only the monitor and computer as follows:
  1. Download and install the INZONE hub application.
  2. Connect the following cables from your computer to the monitor:
    • An HDMI (or other) cable to transmit the video
    • A USB cable to transmit data for the update
    Example connection method: Use HDMI port 1 (A) for the video input connection and the USB Type-C terminal (B) for the USB connection.
    Cables are connected to the A and B terminals on the monitor from a computer.
    Settings for the example connection method: In the INZONE Hub software or on the monitor menu, under USB Hub, set the KVM SWITCH 1 to HDMI 1 Sync.
Hint: For all connection methods and settings available on the monitor menu or in the INZONE Hub software refer to the following:
The USB Hub setting according to the connecting terminals on the monitor
Download & Install
Follow these steps to update the software of the monitor:
  1. Restart the monitor and computer.
  2. Start the INZONE Hub software.
  3. Select Device Settings.
  4. Select the Update button.
    Note: A notification will be displayed in the System Software Information section when a new update is available.
  5. Read the information on the screen and then select the Update Now button.
    Note: Make sure no other monitors are connected to the computer.
How to check the INZONE monitor software version
Via the monitor screen
  1. Press the Joystick on the rear of the monitor to display the menu.
  2. Move the Joystick to the right to select Others-DDC/CI.
  3. Move the Joystick down and select Software version.
  4. The software version is shown on the monitor screen.
    • Main: Mxxx
    • Sub: xxx
Via the INZONE Hub software
  1. Select the Device Settings tab of INZONE Hub.
  2. The software version is shown under System Software Information.
    • VERSION (MAIN): xxxx
    • VERSION (SUB): xxx
Note: If you don't have a Windows computer, please refer to the Contact support section of this article.
