Applicable Model
This information is for the following models:
  • PXW-Z750
[Overview]
Sony is offering a system software update for Solid-State Memory Camcorder "PXW-Z750"
[Applicable model]
[Applicable system software version]
The applicable products are with the system software version  "Ver.3.10" or earlier
(Please visit the download page and refer to the PDF file in "PXW-Z750_Ver-UpGuide(V3.11).zip" to check the version of the system software installed in your product.)
After updating, the system software version will be "Ver.3.11"
[Contents of update]
Resolved an issue whereby the network function may become unstable if the power is turned off without using the power switch.
IMPORTANT: Installation of firmware is at owner's risk – please refer to our terms & conditions for details. Prior to installation always read installation instructions.
