Applicable Model
This information is for the following models:
  • PXW-Z280V
[Note]
The latest Version has been released.
Click here for a list of software >
Sony is offering a system firmware update
for Solid State Memory Camcorder"PXW-Z280"
[Applicable model]
Solid State Memory Camcorder “PXW-Z280”
[How to upgrade]
Please refer to "PXW-Z280_V500_Update_manual_E.pdf" included in the download contents in this page.
[Applicable system firmware version]
The applicable products are with the system firmware version “Ver.5.00” or earlier.
(Please visit the download page to check the system firmware version installed on your product.)
After updating, the system firmware version will be “Ver.6.00”.
[Contents of update]
1. Strengthen cooperation with C3 portal
  -Supported cloud service management of "All files".
   It is now possible to save the camera's "All files" to the cloud service or read them from
   the cloud service to the camera. This makes it possible to manage multiple "All Files" on
    the cloud service.
  -Supported automatic file transfer
   Until now, clips were selected and transferred after recording was completed, but by
   turning on the automatic file transfer function, it is now possible to automatically
   transfer to the cloud service set before shooting every time one clip is recorded.
2. Audio level meter CH1/CH2 and CH3/CH4 display switching support
   -The audio level meter displayed on the screen can now be switched between CH1/CH2
    and CH3/CH4 displays by setting the Audio Output > Monitor CH in the Audio menu.
3. Supports assignable buttons for audio monitor channel switching
   -Audio monitor channel settings can now be assigned to assignable buttons..
    By assigning "Audio Monitor CH" and "Audio Mon. CH Switch", you can now select
    any audio monitor channel with the assignable button..
4. Expanding the Number of Planning Metadata File Displays
   -Changed the maximum number of files displayed when loading the planning metadata
    file from 64 to 512.
5. Linkage between "Slow & Quick Motion" setting toggle and proxy recording setting
   -When proxy recording is On, setting "Slow & Quick Motion" to On temporarily turns off
    proxy recording, but when "Slow & Quick Motion" is turned off, proxy recording is
    turned On again.
6. Reference signal for Zebra display when SDR Preview function is in operation
   -The reference signal when the Zebra is displayed during the operation of the SDR
    Preview function has been reviewed.
7.  Fixed focus setteing display problem
      -Fixed a bug that AF may be incorrectly displayed in Full MF mode after startup.
8. Improved security and stability.
*For the setting and details of the above functions, refer to the instruction manual.
*Please use Content Browser Mobile version 3.7.0 or later.
*Please use C3 Portal App version 2022.4.0 or later.
*Please use PWS-100RX1/110RX1 series version 1.19.0
IMPORTANT: Installation of firmware is at owner’s risk – please refer to our terms & conditions for details. Prior to installation always read installation instructions.
