Applicable Model
This information is for the following models:
  • SEL100400GM
About this download
Notes:
Benefits and Improvements
  • Adds support for continuous shooting with AF/AE tracking up to a maximum of 120 images/second when used with the ILCE-9M3 camera body
    Note: During continuous shooting at 60 or 120 images/second, the aperture value of the lens is fixed at the aperture value set for the first image. Either set ISO sensitivity to AUTO or use the P/A shooting mode to ensure appropriate exposure when the subject brightness changes during continuous shooting.
Previous Benefits and Improvements
The following benefits and improvements are also included in this update.
  • Improves the Image Stabilization performance when used with the ILCE-7RM5 camera
  • Improves operational stability
  • Improves continuous autofocus (AF-C) performance while zooming in when attached to ILCE-9
    Note: Requires the latest ILCE-9 Camera Firmware Update.
File Info
File Name
  • Update_SEL100400GMV4D.exe
File Version
  • 04
File Size
  • 4.11 MB (4 317 344 bytes)
Release Date
  • 05-12-2023
Preparation
Check the system software version of your lens
Follow the instructions below to check the lens system software version. If the system software version is Ver.03 or earlier, the update is required.
  1. On the camera, select MenuSetupVersion.
  2. The lens system software version is displayed.
    Note: If you are using the QX series, start the Lens System Software Updater on your computer and check the lens system software version by running the update.
    The version will be displayed in the center of the screen.
System Requirements
Operating Systems
The latest version of the lens system software update is compatible with the following versions of the Microsoft Windows operating system:
  • Windows 11
  • Windows 10
Computer Hardware
The latest version of the lens system software update is compatible with the following hardware:
  • An Intel or AMD-based computer (ARM-based computers are not supported)
  • Hard disk space: 200 MB or more
  • RAM: 512 MB or more
    Note: Please close all other application software before updating the lens system software.
Other items for α Interchangeable-Lens Camera
  • Camera power source: Fully charged rechargeable battery pack or dedicated AC adaptor (sold separately)
    Note: The update can be performed only when the remaining battery level is (three bars) or more. We recommend that you use a fully charged battery or the dedicated AC adaptor (sold separately). Detach the vertical grip before you update the lens system software.
  • USB cable supplied with the camera
    Note: Update functionality is not guaranteed with any other USB cable.
Other items for Camera - Broadcast & Production
  • Power source for the camera: The dedicated AC adaptor
Download & Install
Important Notice
  • This lens system software update can be performed only when the lens is attached to the E-mount body camera. You cannot perform the lens system software update using another camera.
  • Attach the lens to the camera before performing the lens system software Update. Make sure the camera is turned off.
  • When performing the lens system software Update, please use a fully charged rechargeable battery pack or the dedicated AC adaptor (sold separately). (for α Interchangeable-Lens Camera)
  • When performing the lens system software Update, please use the dedicated AC adaptor. (for Camera – Broadcast & Production)
  • Do not remove the battery during the update; otherwise, the camera may become inoperable due to the sudden power shutdown.
  • Remove the memory card from the camera beforehand.
  • Please ensure that the battery and AC adaptor are removed before the lens with the update is attached. (For professional category cameras)
  • Prevent your computer from going into sleeping mode. In case the computer goes into sleeping mode and the update is interrupted, redo the complete update process from the start.
  • Ensure that all devices other than the computer are disconnected.
How to download the Lens System Software Updater:
  1. Make sure that you are logged on as a user with administrative rights.
  2. Click the Download button above.
  3. After reading the disclaimer, click Download.
  4. The Update_SEL100400GMV4D.exe file will start.
  5. Save the file to the desktop of your computer (recommended).
    Note: With the standard settings of Microsoft Edge, the update file will be saved in your Downloads folder. Click the Desktop tile from the Start screen and find the downloaded file in the Downloads folder by using Explorer.
Once the file has been downloaded successfully, you're ready to install the lens system software Update.
Step 1: Start the Lens System Software Updater
  1. Close all currently running programs on your computer.
  2. Double-click the Update_SEL100400GMV4D.exe file you downloaded to start up the Lens System Software Updater.
    Note: The Lens System Software Updater window appears.
  3. Turn on the camera. If the camera has already been turned on, turn it off and then turn it on again.
    Note: According to the instruction on the Lens System Software Updater, select MenuSetupUSB Connection on the camera, and check if Mass Storage is selected. (If you are using the QX series, this step is not necessary.) If a mode other than Mass Storage is selected, please select Mass Storage.
  4. Remove the memory card from the camera beforehand. Connect the camera to the computer with the supplied USB cable.
    Note: If an error message appears on the computer screen, please try the following methods.
    • Disconnect the USB cable from the camera, then reconnect the USB cable.
    • If there is another USB terminal with the computer, reconnect the USB cable to another USB terminal.
  5. Confirm (the USB icon) is displayed on the task tray at the lower right corner of the computer screen.
    Note: If (the USB icon) is not displayed on the task tray, please proceed to the next step.
  6. Click Next on the Lens System Software Updater. The Lens System Software Updater window appears on the computer and Follow computer instructions appear on the camera screen.
    Note: From now on, never turn off the camera until the lens system software update is completed. It might take a few minutes to screen changes depending on the camera model.
    • Computer
      Check the version screen
    • Camera
      Follow computer instructions screen
    Troubleshooting:
    • If the message The update is not available for your model. appears, check if the lens system software file you're trying to install is the correct file for the lens that is attached to your camera. In case the correct Lens System Software Updater is running, close the updater, disconnect the USB cable, turn off the camera, and go back to Step 1.
    • If the message Could not find camera with the lens for this update mounted. appears, check if your camera is listed in the Relevant Products section and if the camera is connected to the computer with a USB cable.
  7. Click Next on the Lens System Software Updater. The current version and the version after the update appear on the lower left part of the screen. If the current lens system software version is Ver.04, the update is not required. In this case, stop the USB connection and click Finish, turn off the camera, remove the battery pack and/or the AC adaptor, reinsert the battery or reconnect the AC adaptor, and turn on the camera.
    • An update is required
      The [Current Version] on the lower left of the screen is showing 03 or earlier, and the [Version after the update] is showing 04.
    • An update is not required
      The [Current Version] and the [Version after the update] on the lower left of the screen are showing 04.
  8. Confirm the Current version is Ver.03 or earlier, and click Next. The data is transferred to the camera (approximately 5 seconds).
    Note: Never turn off the camera or disconnect the USB cable while updating.
  9. When the data transfer is finished, the following screen appears:
    Run the update screen
    Click Finish.
  10. The update process starts and the progress bar is displayed on the camera (approximately 60 seconds).
  11. The update process is finished when the Lens update complete message is displayed on the camera. If you are using the QX series, the update process is finished when the screen of the QX series disappears.
  12. Click (the USB icon) on the task tray at the lower right corner of the computer screen to stop the USB connection.
    Note: If (USB icon) is not displayed on the task tray, please proceed to the next step.
  13. Disconnect the USB cable.
    Note: After finishing the update, turn off the camera, remove the battery pack and/or the AC adaptor, reinsert the battery or reconnect the AC adaptor and turn on the camera.
Step 2: Confirm the lens system software version is Ver.04
Questions & Answers
The update does not complete
When the monitor remains black for more than 10 minutes, follow these steps to troubleshoot the issue:
  1. Disconnect the USB cable from the computer.
  2. Remove the battery and AC adaptor from the camera, leave it for a few minutes, then insert the battery again or connect the AC adaptor.
  3. Restart the computer.
  4. Turn on the camera and perform the installation process again.
