Applicable Model
This information is for the following models:
  • SRS-XB23
  • SRS-XB33
  • SRS-XB43
About this download
Benefits and improvements
  • Improves the connection compatibility with Party Connect compatible devices
Previous Benefits and Improvements
View previous benefits and improvements
System Requirements
  • An Android device (V5.0 or later) or an iOS device (iOS 11.0 or later)
  • An active Internet connection
  • The latest version of the Sony | Music Center application must be installed
  • The speakers must be connected to your Android or iOS device
File Info
File Name
  • Firmware update to 4800 for SRS-XB23/SRS-XB33/SRS-XB43
File Version
  • 4800
File Size
  • SRS-XB23: 1.49 MB (1 568 736 bytes)
  • SRS-XB33: 1.53 MB (1 610 336 bytes)
  • SRS-XB43: 1.53 MB (1 611 776 bytes)
Release Date
  • 21-06-2022
Preparation
Check the firmware version
If the version is displayed lower than 4800, we strongly recommend updating the firmware. If you're not sure, it's easy to check which version of the firmware you currently have:
  1. Turn on the speaker.
  2. Launch the Sony | Music Center application.
  3. Connect your speaker to the Sony | Music Center application.
  4. Select Settings.
  5. Select System.
  6. Confirm the firmware version (numbers in red box).
    Current firmware version of the speaker
Important Notice
  • DO NOT perform the update in a location where the Wi-Fi signal is inconsistent, such as:
    • on a train or in a place where Wi-Fi signals become congested
    • near a microwave, cordless phone, or any other devices that use the 2.4 GHz band frequency radio waves
  • Make sure both devices (Android or iOS device and speakers) are fully charged.
  • Make sure that your unit is connected to a power outlet via the USB AC adapter (SRS-XB23/SRS-XB33) or AC adapter (SRS-XB43) before starting the update.
  • Disconnect all other Bluetooth devices such as wearable devices or smart watches from your Android or iOS device before starting the update.
Before you upgrade
  • Once updated, the firmware cannot be reverted to an earlier version.
  • For Android devices, the update process will take approximately 3 minutes to complete.
    The file size is about 1.49 MB for SRS-XB23 and approx. 1.53 MB for SRS-XB33/SRS-XB43.
    For iOS devices, the update process will take approximately 10 minutes to complete.
  • Depending on the radio wave environment and your Android or iOS device, it may take longer to complete.
  • To update these speakers, follow the procedure below.
    • Download data from the server to the iOS device or the Android device.
    • Transfer data from the iOS device or the Android device to the speakers.
    • Execute the update with the speakers.
Download & Install
To update these speakers, follow the procedure below:
  1. Download data from the server to the iOS device or the Android device.
  2. Transfer data from the iOS device or the Android device to the speakers.
  3. Execute the update with the speakers.
Step 1: Install the update
  1. Connect to a power supply outlet.
    • SRS-XB23/SRS-XB33
      Use the USB AC adapter and supplied USB Type-C cable to connect the unit's DC IN 5 V port to a power outlet.
    • SRS-XB43
      Connect the supplied AC adapter to the speaker's DC IN 5 V port and an AC outlet.
      Note: The software update cannot be performed when using battery power only.
  2. Turn on the speaker.
  3. Launch the Sony | Music Center application.
  4. Connect your speaker to the Sony | Music Center application.
  5. The following screen will be shown when the connection has been established.
    image of the Sony | Music Center application screen
  6. If an update is applicable, Update the software of the speaker. will be displayed and you can press More Info.
  7. Verify that Version 4800 is displayed and press OK to start the update.
  8. Once the download starts, it will automatically move to the next screen after the download is completed.
  9. Once the transfer starts, it will automatically move to the next screen after the transfer has been completed.
    Note: Do not turn off your speakers while downloading updates, transferring data, or updating, otherwise, the speakers may become unusable. When the software update is completed, press OK.
  10. If the screen is not displayed, check whether the version has been upgraded in the following step.
  11. The speaker automatically turns off when the software update ends.
Step 2: Check the update was successful
After the update, confirm that the new version has been installed successfully by following the Check the firmware version section steps.
If the firmware version shown is 4800, the upgrade was successful.
Questions & Answers
An update error message appears.
  1. Press OK.
  2. Restart (turn the power off then on) the speaker.
  3. After that, restart Sony | Music Center and update again
Even though the update failed during the process, check the firmware version. If the Version is shown as 4800, the firmware update was successful. If not, try the firmware update again. You can check the Version from the setting in the Sony | Music Center application. To find out how to check the version, go to the Check the firmware version on this page.
