Applicable Model
This information is for the following models:
  • AXS-AR1
[Note]
The latest Version has been released.
Click here for a list of software >
<UPDATE POINTS>
- Support AXS-A1TS66
- Support Mac with Apple M1 chip
- Change the led lit at AXS Memory insertion
   The LED is lit blue when the inserted AXS Memory is accessed while the mount process. (If the version is 1.0x, the LED is not lit.)
- Support getting the additional AXS Memory Log function
- Change the mount condition of AXS Memory
   When the error is detected in the mount process, the mount process is continued if the error is not critical.
- Fix the response is delayed when the S.M.A.R.T command is received while another S.M.A.R.T command is executed.
- Modify the stability
<HOW TO UPDATE>
Please use AXSM Drive Utility (https://www.sonycreativesoftware.com/axsmdrive) for updating AXS-AR1 firmware.
Regarding detail procedure, please refer to the help of AXSM Drive Utility software page 10 “Updating the Firmware of the AXS-AR1/AR3”.
<SUPPORT OS>
OS X Yosemite 10.10.5
OS X El Capitan 10.11.6
macOS Sierra 10.12.6
macOS High Sierra 10.13.6
macOS Mojave 10.14.6
macOS Catalina 10.15.7
macOS Big Sur 11.6.3
macOS Monterey 12.2
