Applicable Model
This information is for the following models:
  • PVM-X1800
[Updates of this version]
  • The following new features and improvements are available.
    1. Embedded Audio/Time code over an Enhanced Monitor Output signal
    2. 3D LUT Baked Output License PVML-TDX1
    3. Signal Conversion Output License PVML-SCX1
    4. IMD
    5. Closed Caption
    6. Chroma up
    7. Grid Display
    8. Parallel remote
    9. Improvement of OSD Menu response(Quicker response than V3.01 or before)
    10. Display error in Quad View
    11. Improvement of Operational response when using IMD
      For further details, please refer to the Release Notes for "PVM-X3200_X2400_X1800_V4_01.pdf".
[Applicable version]
  • PVM-X1800 Ver.1.04 or later
 Note:
  • The software version for the monitor can be found on the Unit Status of the Status menu.
[Preparation]
  • You will need 1 USB memory stick for the installation.
    Specification: USB 3.0 up to 8GB, FAT32 format
    For more details, please read “Handling a USB memory stick” in the operating instructions of the PVM-X3200, PVM-X2400 and the PVM-X1800.
 Note:
  • You need to upgrade both the software and the FPGA.
           In the case of Ver.1.04 or Ver.2.00, this update procedure takes about 1 hour and 25 minutes per PVM-X3200/X2400/X1800 unit.
           In the case of Ver.3.01 or later, this update procedure takes about 1 hour and 5 minutes per PVM-X3200/X2400/X1800 unit.
[How to update]
  • Please refer to "Release Note for_PVM-X3200_X2400_X1800_V4_01.pdf”.
