Applicable Model
This information is for the following models:
  • LF-S50G
About this download
Benefits and Improvements
  • Improves secure communication
    IMPORTANT: This firmware update must be performed in order to keep using the Chromecast built-in music distribution service. It will be automatically installed at a time when there is an active network connection available, and the device is not being used.
  • Modifies the Google Home app setup protocol
Previous Benefits and Improvements
View previous benefits and improvements
File Info
File Name
  • Firmware update 97368124 for LF-S50G
File Version
  • 97368124
File Size
  • 135 MB (142 112 228 bytes)
Release Date
  • 30-11-2021
Preparation
Check the firmware version
If the version is displayed as 96136122 or lower, we strongly recommend updating the firmware.
If you're not sure, it's easy to check which version of firmware you have:
  1. Connect the unit to the same Wi-Fi network as your smartphone, using the Google Home application.
  2. Start the Google Home application on your smartphone.
  3. Select the Home icon.
  4. Select the LF-S50G device icon.
  5. Click the device settings icon.
  6. System firmware version will appear in the Information category.
Install
The software update of this product will be automatically updated to the latest software version while connected to the Internet via a Wi-Fi network. The software update will be delivered from time to time when a new feature becomes available or the update is required for stable use.
Important notice
  • You cannot disable the automatic software update.
  • Previous versions of the software cannot be retrieved.
  • Do not power off the product while updating. The product may not be operational while updating.
  • To use this product, a Wi-Fi connection and a Google Account are necessary, and you will need to consent to Google's Terms of Use and/or Privacy Policy.
  • By using this product, agreement to Sony's EULA is necessary.
  • Software for this product is automatically updated from time to time, and you cannot choose or refuse to download this automatically-updated software.
  • During the update, the LED will blink white and the clock will count from 0 to 100.
