Applicable Model
This information is for the following models:
  • SEL50F12GM
Required Downloads
Read this section before downloading the file.
To install this update, you need to download the Sony Camera Driver first. For details, read the How to download the Sony Camera Driver section in this article.
About this download
NOTES:
  • This Lens must be attached to an E-mount body camera to perform this update.
  • Some models cannot be used for this update. (model list).
  • When using the PXW-FS7M2, follow the steps as specified in the PXW-FS7M2 instruction manual.
Benefits and Improvements
  • Improves an issue where, on rare occasions, the aperture value may become unstable when the IRIS ring is operated
File Info
File Name
  • Update_SEL50F12GMV2D.dmg
File Version
  • 02
File Size
  • 1.8 MB (1 816 061 bytes)
Release Date
  • 21-06-2021
Preparation
This Lens system software update can be performed only when the lens is attached to the camera. Be sure to attach the target lens to the camera body before starting the update. Also, be sure to turn off the power of the camera when attaching the lens.
Check the system software version of your lens
Follow the instructions below to check the lens system software version. If the system software version is Ver.01, the update is required.
NOTE: If the date and time setting screen appears when you turn on the power of the camera, be sure to set it.
  1. On the camera, select MenuSetupVersion.
  2. The lens system software version is displayed as illustrated below.
    NOTE: If you are using the QX series, start the lens system software updater on your PC and check the lens system software version by running the update.
    Image indicating the current system software version
System Requirements
Operating Systems
The latest version of the lens system software update is compatible with the following Macintosh versions:
  • macOS 10.14, 10.15, 11
Computer Hardware
The latest version of the lens system software update is compatible with the following hardware:
  • Mac with an Intel processor (Mac with Apple silicon is not supported)
  • Hard drive space: 200 MB or more
  • RAM: 512 MB or more
Other items for α Interchangeable-lens Camera
  • Power source for the camera: Fully charged rechargeable battery pack or dedicated AC adaptor (sold separately)
    NOTE: The update can only be performed when the battery power level is (three bars) or more. We recommend that you use a fully charged battery or the dedicated AC adaptor (sold separately). Detach the vertical grip before updating lens system software.
  • USB cable supplied with the camera
    NOTE: Update functionality is not guaranteed with any other USB cable.
Other items for Professional/Camera - Broadcast & Production
  • Power source for the camera: The dedicated AC adaptor
  • USB cable supplied with the camera.
Download & Install
Important Notice
  • Please close all other application software before updating the lens system software.
  • Do not remove the battery during the update as the sudden loss of power may render the camera inoperable.
  • Prevent your computer from going into sleeping mode.
  • When connect the camera to a computer, make sure that you only connect a computer.
  • Remove the memory card from the camera before starting the update process.
  • Do not connect the camera and computer yet.
  • Ensure that your computer is connected to the Internet.
  • When performing the lens system software update, please use a fully charged rechargeable battery pack or ​the dedicated AC adaptor (sold separately).
  • Attach the lens to the camera before performing the lens system software update. Make sure the camera is turned off.
for Professional/Camera – Broadcast & Production
  • Use the dedicated AC adaptor when updating.
  • Please ensure that the battery and AC adaptor are removed before the lens with the update is attached
  • Confirm the USB connection settings
    NOTE: Following the instructions in the Lens System Software Updater window, on the camera, select Menu Setup USB USB Connection and check if Mass Storage has been selected. If a mode other than Mass Storage is selected, please select Mass Storage.
How to download the Sony Camera Driver:
  1. Visit the Sony Camera Driver download page.
  2. Click the Download button.
  3. After reading the disclaimer, click Download.
    NOTE: The Camera_Driver_2102a.dmg file will start downloading.
  4. Save the file to the desktop of your computer (recommended).
    NOTE: File Size: 130 KB (129 582 bytes)
How to download the Lens System Software Updater:
  1. Click the Download button above.
  2. After reading the disclaimer, click Download.
    NOTE: The Update_SEL50F12GMV2D.dmg file will start downloading.
  3. Save the file to the desktop of your computer (recommended).
Once the file has downloaded successfully, you're ready to install the upate.
Step 1: How to Install the Sony Camera Driver
  1. Close all programs currently running on your computer.
  2. Double-click the Camera_Driver_2102a.dmg file you downloaded. Do not connect the camera at this point.
    NOTE: If you have connected the camera to a computer, disconnect it before following the procedure.
  3. The Sony Camera Driver Installer is expanded.
  4. Double-click the SonyCameraDriver.pkg icon.
  5. The installer screen opens. Proceed as instructed.
  6. You are asked to allow the system to start installation. Type the password for the administrative account.
    NOTES:
    • If the operating system displays the System Extension Blocked dialog message (the actual message will vary depending on the operating system version), click the Open Security Preferences button. The macOS Security & Privacy screen opens.
    • If the operating system does not display the System Extension Blocked dialog message, go to Step 2: Start the Updater onward.
  7. In the Security & Privacy screen, open the General tab and then click the key icon. When prompted to enter the password, type the password you used when logging in with the administrator account and then click the Unlock button.
  8. Click the Allow button to allow the system to start loading the system software.
  9. After clicking the Allow button, if you are asked to restart, restart the computer and return to the beginning of the update procedure.
  10. If the Security and Privacy screens does not disappear, please close the window.
Step 2: Start the Lens System Software Updater
  1. Double-click the Update_SEL50F12GMV2D.dmg file you downloaded. Do not connect the camera at this point.
  2. Update_SEL50F12GMV2D is expanded.
  3. Double-click the LensSystemSoftwareUpdater icon.
  4. The message prompts you to allow the application to make changes. Type the password for the administrative account.
  5. The Lens System Software Updater will start.
    NOTES:
    • If the system is not ready to start updating, an error message appears. Take appropriate action according to the message and then double-click LensSystemSoftwareUpdater again.
    • If the message You need to restart your computer. appears, restart the computer and then double-click LensSystemSoftwareUpdater again.
    • If the message You need to install Sony Camera Driver appears, perform the procedure described in Step 1: How to Install the Sony Camera Driver, then double-click LensSystemSoftwareUpdater again.
    • If the message Check the Security & Privacy setting. appears, perform steps 7 and 8 in the Step 1: How to Install the Sony Camera Driver section, then restart the computer and double-click LensSystemSoftwareUpdater again.
  6. Turn on the camera and connect the camera to the computer with the supplied USB cable, USB Mode appears on the LCD screen of the camera.
  7. Click Next on the lens system software updater. The lens system software updater window appears on the computer and Follow computer instructions. appears on the camera screen.
    NOTE: From now on, never turn off the camera until the Lens system software update is completed. It might take a few minutes to screen changes depending on the camera model.
    • Computer
      Check the version screen
    • Camera
      "Follow computer instructions" screen
    Troubleshooting:
    • If the message The update is not available for your model appears, check if the lens system software file you're trying to install is the correct file for the lens which is attached to your camera. In case the correct lens system software updater is running, close the updater, disconnect the USB cable, turn off the camera, and go back to Step 2: Start the Lens System Software Updater.
    • If the message Could not find camera with the lens for this update mounted. appears, check if your camera is listed in the Relevant Products section and if the camera is connected to the computer with USB cable.
  8. Click Next on the lens system software updater. The current version and the version after the update appear on the lower left part of the screen. If the current lens system software version is Ver.02, the update is not required. In this case stop the USB connection and click Finish, turn off the camera, remove the battery pack and/or the AC adaptor, reinsert the battery or reconnect the AC adaptor and turn on the camera.
    • Update is required
       Image indicating the current system software version on the System Software Updater
    • Update is not required
      Image indicating the latest software version on the System Software Updater
  9. Confirm Current version is Ver.01, click Next. The data is being transferred to the camera (approximately 5 seconds).
    NOTE: Never turn off the camera nor disconnect the USB cable while updating.
  10. When the data transfer is finished, the following screen appears:
    Run the update screen
    Click Finish.
  11. The update process starts and the progress bars is displayed on the camera (approximately 30 seconds).
  12. The update process is finished when the Lens update complete. message is displayed on the camera.
    If you are using the QX series, the update process is finished when the screen of the QX series disappears.
  13. Disconnect the USB cable.
    NOTE: After finished the update, turn off the camera, remove the battery pack and/or the AC adaptor, reinsert the battery or reconnect the AC adaptor and turn on the camera.
Step 3: Confirm the lens system software version is Ver.02
  2. The lens system software version is displayed as illustrated:
    Image indicating the updated software version
Questions & Answers
The update does not complete
If the monitor remains black for more than 10 minutes, follow these steps to troubleshoot the issue:
  1. Disconnect the USB cable from the computer.
  2. Remove the battery and AC adaptor from the camera, leave it for a few minutes, then insert the battery again or connect the AC adaptor.
  3. Restart the computer.
  4. Turn on the camera and perform the installation process again.
