Applicable Model
This information is for the following models:
  • KD-32W800
About this download
Benefits and Improvements
  • Resolves an issue where recorded items were incorrectly deleted
  • Resolves an issue where some apps couldn’t cast to the TV
  • Resolves an issue where a dotted line appears on top of the screen while watching certain channels
  • Resolves an issue where recording wasn’t possible when the TV setup was done in certain languages
  • Update organisation name on EULA change from Sony Home Entertainment & Sound Products Inc. to Sony Corporation
Previous Benefits and Improvements
The following benefits and improvements are also included in this update.
  • Resolves a continuous restart issue after software update
  • Includes Greece in the country list
Restrictions
  • Only for use with TV sold in Europe. Not all models are sold in all countries/regions.
Preparation
Check the software version
Your software may already be up to date. If you're not sure, it's easy to check which version of software you have by following these instructions:
  1. Turn on your TV and press the HOME button on the remote control.
  2. Select Settings.
  3. Select Device Preferences.
  4. Select About, then the software version number is shown on the Software Version row.
If the version number is 10017 or higher, you already have the most recent software version and updating is not required.
There are 2 ways to update the firmware on your BRAVIA TV:
  • Using the System software update feature (easy)
  • Using a USB flash drive
Using the System software update feature (easy):
Sony provides software updates in order to enhance functionalities and provide users with the latest TV experience. The easiest way to receive software updates is via the internet connection to the TV. If you get the notification for a system software update, you can install it from the Home Menu.
The new firmware update will be rolling out gradually to all Internet-connected TVs over the weeks following its release.
IMPORTANT: The following System Requirements, File Info, and the Download & Install sections relate to the USB flash drive update procedure. You can ignore them if you completed the update using the System software update feature.
For other FAQs about Troubleshooting, please see the Questions and Answers on the Sony Support Site.
Using a USB flash drive:
You can also update the software by using a USB flash drive. If an Internet connection is not set up on your TV, or you don't want to wait for the update via System software update feature, try to download and update using a USB flash drive as instructed below.
System Requirements
What You Need
  • a computer with access to the Internet
  • a USB flash drive
    Note: You can update your TV even if there are other files in the USB flash drive.
File Info
File Name
  • Firmware update to v10017 for TV
Zip File Name
  • sony_atvondfull_braviatl_10017000_wwa_auth.zip
File Version
  • 10017
File Size
  • 1 475 285 480 bytes
Release Date
  • 18-05-2022
Download & Install
Important Notice
  • Read the instructions carefully or you could end up causing the TV to become unresponsive or require a repair.
  • Do not turn the TV off or disconnect it from the power while it's updating.
  • Do not press any buttons, except the ones mentioned in the instructions.
How to download the Updater
Before you install the update, you'll need to download it from the Internet and save it to a USB flash drive.
  1. Download the update file to your computer.
    1. Click the Download button on the top of this page, then read and accept the terms and conditions.
    2. Click the Download button on the bottom of the page to download the update file on your computer.
  2. Verify the downloaded file name and size (see the File Info section).
  3. Extract the downloaded file to a location on your computer you can easily find.
  4. After you extract the downloaded file, you will find a file (SY0M_TPM219E_EUR_MT9675_ALLPANEL_braviatl.XXXXX_YYYYYYYY_ZZZZ.pkg).
    Note: XXXXX is the version of this software update.
  5. Rename the .pkg file as "Sony_dtv_braviatl_XXXXX000_wwa_auth_no_tvcertificate.bin".
  6. Insert the USB flash drive into your computer.
  7. Copy or drag and drop the file (Sony_dtv_braviatl_XXXXX000_wwa_auth_no_tvcertificate.bin) to the root directory of your USB device.
    Note: The root directory is the first or top-most directory of the device, which contains all the other folders.
  8. Remove the USB flash drive from your computer and continue to the next section.
Step 1: Install the update
Once you've downloaded the update file and prepared your USB device, you can install it on your TV. The process can take up to 15 minutes and during the installation your TV will turn off before turning itself back on. Please follow the simple steps below:
  1. Turn on the TV.
  2. Make sure that no USB devices are inserted into your TV.
  3. Insert your USB flash drive containing the file (Sony_dtv_braviatl_XXXXX000_wwa_auth_no_tvcertificate.bin) into a USB port of the TV set.
    Note: Any USB slot can be used if the TV has multiple USB ports.
  4. Unplug the TV's AC power cord (mains lead) from the electrical socket.
  5. TV will be showing Software update in progress after plug the AC power cord (mains lead) back.
  6. After several minutes, the TV will restart automatically.
    WARNING! During the software installation process, please:
    • Do not remove the USB device
    • Do not turn off the TV
    • Do not disconnect the TV from the power supply
  7. Carefully remove the USB device from the USB slot.
Step 2: Check that the update was successful
Check the current software version to confirm that the update has successfully been installed.
  • If the version number is 10017, the software update was successful.
  • If the version number isn't 10017, download and install the update again.
Questions & Answers
Possible Issue During the Update
Need more information? See our FAQs about updating the software over the Internet:
  • Will my personal settings be deleted after the update?
    No, all your personal settings will be kept.
  • Can I install an older version of the software?
    No, To ensure that your TV remains at optimum performance, the installation of an older software version is not recommended. The latest software version contains all the benefits and improvements of previous versions.
  • Is it normal for the TV to turn off during the update process?
    Yes, it's normal for the TV to restart during the update process. It will take a longer time for the TV to restart while installing the new software.
What to do if you have problems updating your TV firmware
If the message An error occurred during the software update is displayed on the TV screen, please proceed to the following procedures for a possible solution:
  1. Make sure the TV has at least 2 GB available in the storage.
    1. On the remote control, press the HOME button to display the HOME Menu.
    2. Navigate to Settings and select it.
    3. Navigate to Device Preferences and select it.
    4. Navigate to Storage and select it.
    5. Navigate to Internal Shared Storage and select it.
    6. Navigate to Available and check the current available storage.
  2. Turn off the TV by pressing the POWER button on the TV set.
  3. Press the POWER button again, and proceed with the installation process again.
  4. If the message No newer version of the TV software was found is displayed on the TV screen, your TV already has the newest software version installed, so you don't need to update it.
Note: If you are trying to update the software using a USB flash drive, make sure your USB flash drive is in good working order.
For other FAQs about Troubleshooting, please see the Questions and Answers section on the Sony Support Site.
