Applicable Model
This information is for the following models:
  • MPC-3610 / VENICE
[Note]
The latest Version has been released.
Click here for a list of software >
Sony is offering a system firmware update for Digital Motion Picture Camera VENICE “MPC-3610”.
Sony highly recommends this firmware update for immediate installation on all VENICE systems to ensure highest performance.
To improve the performance of MPC-3610, the updated software is released. (V6.01)
There are no new function added in this version(V6.01) from previous version(V6.00).
To upgrade from V3.00 or earlier, it is necessary to change the hardware in advance. In this case, please contact Sony sales representative or dealers for getting firmware.
AXS-R7 must be updated to V6.00 firmware for VENICE V6.01 if you use AXS-R7.
 Note: UpdateManual and ReleaseNote are included in the zipped download file with main firmware module.
[Applicable model]
[Applicable system software version]
The applicable products have system firmware version “Ver.4.00” or later.
After updating, the system firmware version will be “Ver.6.01”.
<Contents of V6.00>
1. Imager mode FPS expansion (5.7K 16:9 72FPS, 4K 6:5 72FPS, 3.8K 16:9 110FPS)
2. ART file support added to look
3. User 3D LUT added to viewfinder output
4. Added selectable SDI 3G LevelA output function
5. Added support for two types of user frame lines
6. Added support aspect ratios for frame lines (1:1, 9:16)
7. Addition of flicker reduction function
8. Separate adjustments for REC beep and alert sounds
9. Improved display function (Genlock & timecode Lock condition, status display on the web remote panel)
10. Improved metadata operation (Tint/Roll information, Zoom extended metadata)
11. Others
 IMPORTANT: Installation of firmware is at owner’s risk - please refer to our terms & conditions for details. Prior to installation always read installation instructions.
