Applicable Model
This information is for the following models:
  • PDW-HD1550
NEW FEATURES & IMPROVEMENTS
1) Function to set LOCAL KEY MAP
2) Function to set NEXT/PREV button enable or disable
3) AUTO RECALL of F-MENU is supported
4) Enhancement of the security of network connection
*Please refer to [PDW-HD1550_V161_ReleaseNote_E] which is included "Release note-Procedure-History.zip" in this page for more details.
*Please refer to [PDW-HD1550 Version Up History(V110_150)] which is included "Release note-Procedure-History.zip" in this page for the past version contents
INSTALLATION PROCEDURE
Please download the update manual [PDW-HD1550_FW_Update_Procedure] which is included "Release note-Procedure-History.zip" in this page and follow the steps.
REQUIRED BINARY PACKAGE
Please check the serial number of your set.
You can get serial number [S/N] from the name plate of right side panel of the set.
And please download required binary package in this page as following;
Your Set Serial Number [SN]                         Required Binary Package
1. 10001 – 11076, 50001-50177                    PDW-HD1550_V161_Package_1
2. 11077 or higher, 50178 or higher              PDW-HD1550_V161_Package_2
*Please update each file in the Package. Order of updating does not matter.
NOTES
– If you are currently using the set in the system with other equipment or applications, please be sure to perform test operation again after updating the firmware.
– During firmware update, please do not turn off the power of the set. Please do not use the battery and do use AC for power supply and be careful for the connection cable not to be plugged out.
– In case the update fails, please contact your Sony dealer or sales company service nearby.
