Applicable Model
This information is for the following models:
  • ILME-FX6V
  • DSC-RX0M2
  • DSC-RX0M2G
  • DSC-RX100M7
  • DSC-RX100M7G
  • ZV-1
  • ILCE-7C
  • ILCE-7CL
  • ILCE-7SM3
Catalyst Browse
The Catalyst Browse software (free version) allows you to preview XAVC S and XAVC HS video clips, check and edit metadata, apply SteadyShot* correction using metadata, apply color correction, copy clips to the local hard disk, transcode between a variety of formats, and more.
* These products support the SteadyShot function using metadata
Download and contact information for the Catalyst Browse (free version) software
Catalyst Prepare
In addition to the functions included with the Catalyst Browse software, the Catalyst Prepare (paid version) software also includes features bin-based clip management, simple timeline editing using a storyboard, and more.
Download and contact information for the Catalyst Prepare (paid version) software
The following products support the SteadyShot function using metadata:
ILCE-7SM3, ILCE-7C, ILME-FX6, DSC-RX100M7, DSC-RX0M2, ZV-1
NOTES:
  • When using an ILCE model or ILME model, operation is not guaranteed when shooting using other than E-mount lenses
  • When using the ILCE-7SM3, to use the SteadyShot function using metadata, set the SteadyShot function to Off or Active on the camera body before shooting
  • When using the ILCE-7C or ILME-FX6, to use the SteadyShot function using metadata, set the SteadyShot function to Off on the camera body before shooting
