Applicable Model
This information is for the following models:
  • SRG-XP1
[How to upgrade]
  The installation/upgrading procedure is described on the release note which is included in the zipped download file in this page.
[Functions added in Ver. 1.10]
- NDI|HX optional license function is supported.
  NDI|HX streaming function is enabled by installing NDI|HX license.
- Additional languages are supported.
  Following languages are supported for web browser operations.
  Japanese/French/Spanish/German/Italian/Simplified Chinese/Traditional Chinese/
  Korean/Portuguese/Russian/Polish/Hindi/Vietnamese/Thai/Turkish
[Specifications changed in Ver. 1.10]
- Erased date and time display from Live viewer of Web UI
- Changed default zoom mode from "Digital" to "Off"
- Image quality improved.
[Problems corrected in Ver. 1.10]
- There was a problem that when pushed reload button after changing preset name in the Web UI, preset name returned defalut value. This problem has been corrected.
- There was a problem that when DHCP setting was ON, camera name was not changed from RM-IP Setup Tool. This problem has been corrected.
