Applicable Model
This information is for the following models:
Viewing application software for MPEG-4 SStP files.
NOTE
This application software is able to rewrap SStP (.MXF) files to QuickTime (.MOV). Using this capability, you can import SStP (.MOV) files to Apple Final Cut Pro X with SR plug-in (SRPM-10) installed.
COMPATIBILITY INFORMATION (SRW-5800 series)
This s/w is only compatible with SRW-5800/2 (Serial No. 12xxx) with s/w V3.20 or higher AND fitted with an HKSR-5804 Network Interface Board with s/w V3.10 or higher.
This s/w is also compatible with SRW-5800 (Serial No. 10xxx) and SRW-5800/1 (Serial No. 11xxx) models where the hardware has been upgraded to the same specifications as an SRW 5800/2. The SRW-5800 requires an additional hardware modification before the HKSR-58UK upgrade kit can be installed. Contact your local Authorised Service Centre for further details.
