Applicable Model
This information is for the following models:
  • PXW-X500
Regarding the Solid-State Memory Camcorder "PXW-X500" that were upgraded to the software released on June 11, it was found that the camcorder may unintentionally shut itself off when using some connected devices.
We stopped supplying the software when we confirmed the symptom, but the countermeasure software is ready, so we will start supplying it.
For customers who have already upgraded to the applicable software version(V7.00), please upgrade to this latest version(V7.01).
[Overview]
Sony is offering a system software update for Solid-State Memory Camcorder ""PXW-X500""
[Applicable model]
[Applicable system software version]
The applicable products are with the system software version ""Ver.7.00"" or earlier
(Please visit the download page and refer to the PDF file in ""PXW-X500_Ver-UpGuide(V7.01).zip"" to check the version of the system software installed in your product.)
After updating, the system software version will be ""Ver.7.01""
[Contents of update of V7.01]
- In V7.00, when using some connected devices, the camcorder that are being powered by battery may unintentionally shut itself off. This symptom is improved.
[Contents of update of V7.00]
- Last Clip Delete function support
- Focus magnifier mode display function improvements
- File transfer supported from the thumbnail screen
- Certification update menu support
- Password security enhancements
IMPORTANT: Installation of firmware is at owner's risk – please refer to our terms & conditions for details. Prior to installation always read installation instructions.
