Applicable Model
This information is for the following models:
  • PXW-Z750
[Overview]
Sony is offering a system software update for Solid-State Memory Camcorder "PXW-Z750"
[Applicable model]
[Applicable system software version]
The applicable products are with the system software version "Ver.1.00"
(Please visit the download page and refer to the PDF file in "PXW-Z750_Ver-UpGuide(V2.00).zip" to check the version of the system software installed in your product.)
After updating, the system software version will be "Ver.2.00"
[Contents of update]
- XAVC added to subclip recording formats when recording in 1-slot Simul Rec mode
- FTP transfer operation support using the UI of the unit
- Separate QFHD and HD Detail settings configurable from 700P remote control device
- HDR function name change
- "SR Live for HDR" metadata support
- Certification update menu support
- Password security enhancements
IMPORTANT: Installation of firmware is at owner's risk – please refer to our terms & conditions for details. Prior to installation always read installation instructions.
