Applicable Model
This information is for the following models:
  • SNC-WL862
[Overview]
This file is the firmware version 1.0.2 of SNC-WL862.
[Software version upgrade method]
To upgrade the camera software to this version, use SNC toolbox Ver.1.7.0 or later. For the version upgrade procedure, refer to the Application Guide.
[Operating environment]
The following operation environment is necessary for the computer used for viewing the camera images or for controlling.
- OS
  Microsoft Windows 8.1 (32 bit version, 64 bit version)
  Microsoft Windows 10 (32 bit version, 64 bit version)
- Web browser
  Microsoft Internet Explorer Ver 11.0 (32 bit)
[Compatibility]
Regarding the functions provided in SNC-WL862 Ver1.0.1, this version does not contain any change for the CGI command, RTSP or other network protocol, or data format for streaming. It is compatible with SNC-WL862 Ver1.0.1 regarding mutual connectivity with external connected devices.
[Additional Function]
Functions added / changed in Ver. 1.0.2
- The security has been enhanced.
- The default setting of Web and RTSP authentication has been changed from Basic authentication to Digest authentication.
[Corrected Problems]
Problems corrected in Ver. 1.0.2
- There was a problem that SNC-toolbox could not find SNC-WL862 camera in the environment without DHCP server.
- There was a problem that upload function of custom language file did not work.
- There were problems in connection with GENETEC Security Center.
- There was a problem with the display of Mac address.
- H.265 did not work in Security Center.
- Motion Detection did not work in Security Center.
- There was a problem that an error occurred in Tampering Detection in Security Center.
- There was a problem that Audio Packet did not appear in Security Center.
- There was a problem in Onvif Motion alarm.
