Article ID : 00118996 / Last Modified : 21/05/2015
Can I view the play data saved in a smartphone on a different smartphone?
    Using your PlayStation Network™ account, you can save the play data in one smartphone or mobile device and view it from another smartphone. To view the play data on another device, follow the steps below.
    1. Install the Smart Tennis Sensor app on your smartphone.
    2. When prompted to register a Sign in ID during initial setup, sign in using the PlayStation Network [formerly known as Sony Entertainment Network (SEN)] account information that you have on your primary device.
      NOTES:
      • When you log in the same PlayStation Network account for multiple mobile devices, the play data between devices will be synchronized.
      • Even if a movie filmed with Live Mode Video is copied to your other device, it will not copy the play data saved on the primary device.
      • It is not possible to view the videos filmed with Live Mode Video on another smartphone.
