Article ID : 00141203 / Last Modified : 13/03/2024Print
How to access and use the Internet browser (Vewd Browser) on Sony's Android TV
    IMPORTANT:
    About Opera TV Browser
    Overview
    Tutorial video
    You can check the detailed instructions in the following video.
    Content featured in this video:
    • 00:36 - 1. Launching the Opera TV Browser
    • 01:23 - 2. Moving the cursor and selecting the desired item
    • 02:49 - 3. Scrolling on the screen
    • 03:20 - 4. Entering text
    • 03:57 - 5. Searching by keyword / Entering a URL address
    • 04:55 - 6. Exiting the Opera TV Browser
    NOTE:
    The browsing screen and menu bar
    browsing screen
    [A]: Menu Bar
    [B]: The Browsing screen
    Displaying the menu bar
    Press the menu button button on the upper part of the screen, to expand the menu area.
    NOTE: If the menu bar is not displayed (automatically hides), scroll the page to the upper part, then move the cursor more to the upper direction. The menu bar appears.
    display menu bar
    The illustration of the menu bar
    menu bar
    [A] History: You can manage the browsing history
    [B] Tabs: You can add the new tabs
    [C] Bookmarks: You can manage the Bookmarks
    [D] Back: Back to the previous page
    [E] Forward: Forward to the next page
    [F] Reload: Reload the page again
    [G] Address bar: You can enter search keyword or URL address
    [H] menu button button: Expand the menu area
    [I] speed dial button: Open the Speed Dial menu
    [J] Opera button button: Open the window for other settings
    How to use the IR Remote Control / Touchpad Remote Control
    You can browse the Internet using the supplied IR Remote Control / Touchpad Remote Control (for the 2015 model).
    NOTE: The supply of a Touchpad Remote Control with the TV depends on your model/region/country. An optional Touchpad Remote Control is available.
    Launching and exiting Opera TV Browser
    Launching the Browser
    1. Press the HOME button on the remote.
    2. Select Internet Browser in the Apps category.
      home menu
    Exit the Browser
    1. Move the cursor to the menu bar and focus the button.
    2. Press the Enter button on the remote. (If you use the Touchpad remote, press the touchpad until it clicks.)
    3. Select Exit Opera TV Browser.
    4. Select OK on the following window.
      exit
    Entering the text / Searching / Entering URL address
    browsing screen
    [A]: The address bar
    [B]: The enterable area
    [C]: The on-screen keyboard
    [D]: GO button
    NOTE: To close the on-screen keyboard, press the BACK button on the remote.
    • Entering the text
      You can enter text using the on-screen keyboard. Follow steps to display the on-screen keyboard.
      1. Move the cursor to the enterable area, such as a text box.
      2. Select the Enter button on the remote (or press the touchpad remote until it clicks).
    • Searching / Entering URL address
      You can also access any website by keyword search or entering the URL directly into the address bar.
      1. Move the cursor to the menu bar and focus the address bar.
      2. Press the Enter button (or press the touchpad remote until it clicks) with the address bar focused.
      3. When the on-screen keyboard is displayed, input the desired search terms or web address, and select GO.
    To operate the TV by the Voice search (only remote controls with the voice button)
    For remote controls with the button, press the button and speak into the microphone that is built into the remote control. For the Voice Search function, refer to the following FAQ:
    How do I use the Voice Search function?
    Using the function of History / Tabs / Bookmarks
    You can use the function of History, Tabs, and Bookmarks.
    Move the cursor to the menu bar and press the mune button button to expand the menu area.
    • Managing the browsing history
      You can access a web site from the previous browsing history. In addition, you can clear the history.
      History
      [A]: The browsing history
      [B]: Clear History
      NOTE:
      • The clear history function will delete entire browsing history. It cannot delete individually history items.
      • You can also delete the browsing history by following steps.
        1. Focus and select the Opera buttonbutton on the menu bar.
        2. Select Settings.
        3. Select Clear History.
    • Using the Tabs function
      You can browse the Internet by switching multiple tabs.
      History
      [A]: Tabs
      [B]: New Tab
      [C]: Close Current Tab
    • Managing the Bookmarks
      You can register the desired or favorite website as bookmarks and access it immediately.
      History
      [A]: Bookmarks list
      [B]: Edit Bookmarks
      [C]: Add to Bookmarks
      Editing the Bookmarks
      You can rearrange the Bookmarks list or delete unnecessary Bookmarks.
      Registering the Bookmarks
      1. Load the page that you want to register to your Bookmarks.
      2. Move the cursor to the menu bar and press the menu buttonbutton to expand the menu area.
      3. Select [C] Add to Bookmarks.
      4. Select OK when following screen is displayed.
        add bookmarks
    Using Speed Dial function instead of a Home page setting
    Opera TV Browser does not have a Home page setting. The Speed Dial can be used as an alternative function. For the Speed Dial function, refer to the following FAQ:
    Can I set a website as the home page of the Opera Internet Browser?
    Enlarging the screen
    You can resize the screen to your desired size.
    1. Move the cursor to the menu bar and select Opera buttonbutton.
    2. Select Settings.
    3. Select your desired enlargement.
