Article ID : 00123853 / Last Modified : 27/02/2024Print
The BRAVIA TV turns on or off automatically
    This article applies to the following issues:
    • The TV repeatedly turns on or off.
    • The TV randomly reboots.
    • The picture turns black while the sound remains.
    Follow the steps below to troubleshoot these issues.
    1. Update the TV software to the latest version.
      Updating the TV software may fix specific issues, including those listed above.
    2. Power Saving or Sleep Timer functions may be set.
      These can cause the TV to turn on or off at certain times or when no activity is detected. If the TV turns on or off at regular intervals, such as 30 minutes or an hour, it is likely that one of these functions is set. To check whether or not your TV has power-saving functions such as Idle TV Standby, On Timer, and Sleep Timer, and for instructions on how to enable/disable them, refer to the following:
    3. Make sure the AC power cord (mains lead) is properly plugged in.
      • If your TV has a power cord (mains lead) that can be removed, make sure that it is firmly plugged in to the back of the TV.
      • If the TV has a separate AC power adaptor, check the connection between the adaptor and power cord (mains lead) as well.
      • Make sure that the power cord (mains lead) is properly plugged in to the AC outlet on the wall.
      • Remove any power strips, surge suppressors, or other similar devices and plug the TV directly into the AC outlet on the wall to verify that these additional devices are not causing the issue.
      • Try a different AC wall outlet and make sure the outlet is not controlled by a switch that is turned off.
    4. Remove the batteries from the remote and check whether or not the issue persists. This tests whether the remote is malfunctioning, rather than the TV.
      Notes:
      • If you are using a multi-function remote in addition to the supplied one, check it too.
      • Covering the remote control sensor of the TV is also a way to check whether the issue occurs. Refer to the manual for information about the location of the remote control sensor. However, you cannot verify using this method if the issue is caused by a remote control which is not an infrared type, such as the Touchpad Remote Control.
    5. Disconnect all external devices from the TV (USB, LAN, HDMI, Antenna, etc.) except the AC power cord (mains lead) and verify that the external devices are not causing the issue. If it has improved, reconnect the devices one at a time until you find the device that is causing the issue.
      1. TV terminals
      2. Remove cables
      3. External devices:
        1. Router
        2. Network devices
        3. HDD USB device
        4. USB wireless LAN adaptor (UWA-BR100)
        5. Video equipment
        6. Antenna (aerial) equipment such as a booster
    6. Make sure the Wi-Fi function of the TV is off.
    7. Perform a power reset.
      Resetting your Sony TV may fix specific issues, including random turn-offs.
    8. Reset the TV to the original factory settings:
    The troubleshooting steps listed above should resolve your issue. However, if the issue persists, your TV may require service.
