Article ID : 00158841 / Last Modified : 20/03/2019
How to delete registered information of all devices paired with the wireless speaker
    Deleting just one set of pairing information is not supported by the wireless speaker. You need to delete all pairing information by initializing the speaker.
    IMPORTANT: All settings of the wireless speaker are then returned to their factory defaults, hence, deleting all network settings and pairing information.
    See below for how to delete pairing information by resetting the speaker to factory settings:
    Model Name
    Operating Instructions
    CAS-1
    1. Turn off the unit.
    2. Press and hold the standby(on/standby) button of the unit for over 10 seconds while the unit is turned off, and the LEDs above the volume control will quickly flash.
    GTK-XB60
    1. Turn on the unit.
    2. Press and hold the FUNCTION Volume_ PAIRING button and the VOLUME - button at the same time for more than five seconds.
    LF-S50G
    2. Press and hold the microphone off(microphone off) button until all four of the status LEDs light in orange.
    LSPX-S1
    2. Press and hold the Volume- button and the on/standby (power) button simultaneously for five seconds.
    SRS-BTD70
    2. Press and hold the VOLUME - button and the INPUT/PAIRING button at the same time for more than five seconds.
    SRS-X1
    2. Press and hold the previous(previous) button, the standby(power) /pairingPAIRING button, and the VOL + button at the same time for more than five seconds.
    SRS-X11
    1. Turn on the unit
    2. Press and hold the power button, the VOL - button, and the VOL + button at the same time for more than five seconds.
    SRS-X7
    SRS-X9
    SRS-X77
    SRS-X88
    SRS-X99
    2. Tap and hold the VOL - button and the ON/STANDBY button at the same time for more than five seconds.
    SRS-HG1
    SRS-XB2
    SRS-XB3
    2. Press and hold the POWER button and the VOLUME - button at the same time for more than five seconds.
    SRS-XB10
    SRS-XB20
    SRS-XB30
    SRS-XB40
    SRS-ZR5
    SRS-ZR7
    2. Press and hold the - (volume) button and the power(power) / pairingPAIRING button at the same time for more than five seconds.
    NOTE: Depending on the model, once the wireless speaker is initialized it may enter standby mode.
