Article ID : 00227243 / Last Modified : 17/07/2020
Can the speaker be charged using the USB AC adaptor for an iPhone/iPad?
    You can use the USB AC adaptor supplied with the iPhone® or iPad® mobile device to charge your wireless speaker.
    • The time required to charge the empty battery fully is ten hours or longer depending on the AC adapter's specifications.
    • It may take longer to charge the battery when the wireless speaker is in use compared to when it's turned off.
      • Make sure to turn it off when charging.
    • We recommend using a USB AC adaptor (AC-UD20) with an output current of 1.5 A and a micro USB cable supplied with your device, or one that complies to the USB standard.
    • Don't use a charge-only micro USB cable with no data transmission function.
