Article ID : 00227219 / Last Modified : 27/06/2019
How to delete the Bluetooth device information of your playback device
    Select your device below for steps on how to delete Bluetooth device information.
    NOTE: Depending on the OS version, the method may differ, for details refer to the manual supplied with the device or contact the manufacturer.
    Android (smartphone, tablet)
    iOS (iPhone, iPad)
    Windows 10
    Windows 8/7
    Mac
    1. From the Home screen, tap Settings - Device connection - Bluetooth.
      The list of Bluetooth devices is displayed.
    2. If the Bluetooth function is set to Off, turn it On.
    3. Tap the  (setting) of the device you want to unpair.
    4. When the next menu is displayed, tap FORGET.
    iOS (iPhone, iPad)
    2. Tap Bluetooth to display the Bluetooth settings menu.
    3. If the Bluetooth function is set to Off, turn it On.
    4. Tap the device you want to unpair.
    5. Tap Forget This Device
    Windows 10
    1. From the Start Menu, click  (settings) - Devices Add Bluetooth or other device to display the Bluetooth menu.
    3. Click the device you want to unpair.
    4. Click Remove device.
    Windows 8/7
    1. Click Control Panel - Hardware and Sound - Devices and Printers.
    2. Right click on the device you want to unpair, and then click Remove device.
    Mac
    1. From the  menu, click System Preferences - Bluetooth to display the Bluetooth settings menu.
    3. Click the product you want to unpair, and then click  (remove) displayed to the right.
