Article ID : 00174169 / Last Modified : 29/08/2017
From 29 March 2013, the SonicStage CP Software will no longer be available
    It's not compatible with the latest versions of Windows - 7 and 8 - and will not work with future versions either so we have decided to discontinue it.
    Already have SonicStage installed?
    If you're using Windows Vista or an older Windows operating system, SonicStage will continue to work as normal on your system.
    However, you will no longer be able to download and install it.
