Article ID : 00232921 / Last Modified : 28/04/2020
I can't connect my Xperia smartphone to my home Wi-Fi network
    • Make sure Wi-Fi is on in your Xperia device and that you can see your Wi-Fi network in Settings. If Connected appears under the network name, you're connected. If not, tap the network name to connect. For secured networks, enter the relevant password. Contact your Internet service provider or your organisation's Wi-Fi network administrator if you don't have a password.
      Attention: Some Wi-Fi networks require that you sign in to a web page before you can access the network. Open the web browser in your device to sign in. Contact the Wi-Fi network administrator for more information.
    • If you are in a location with several Wi-Fi hotspots, make sure you have selected the correct hotspot.
    • Restart your smartphone, and then turn the Wi-Fi on your smartphone off and then on again.
    • Verify that you are in the range of the Wi-Fi router. Check the Wi-Fi signal strength in the status bar. Metal objects, architectural elements and distance can all affect signal strength. If the signal is low, or there is no signal, move closer to your router.
    • Make sure that your smartphone is running the latest software versions
      Click here to check for software updates for your Xperia smartphone.
    • Check the following router settings using a computer. If you are not sure how to change the settings, check the user guide of the router or contact your router manufacturer.
    • Restart the router. Pull the plug out and wait for 1 minute to put it back in. This will reset your router (don't worry, no data is lost).
      Also, confirm if your router is Wi-Fi certified. Your device is Wi-Fi certified, so if the router isn't, your devices may not communicate properly.
    To check if your router is Wi-Fi certified
    Look for the Wi-Fi CERTIFIED logo or phrase on the product packaging or in the product literature, or search the Wi-Fi CERTIFIED products database on the Wi-Fi Alliance website.
    Router Settings
    • Network mode/speed: Change to auto or mixed mode instead of b, g or n.
    • SSID and password: Make sure there are no special characters or characters which are not in the standard ASCII character set.
    • DHCP: Make sure it’s turned on. You could also try setting a static IP address if you have problems accessing the internet using your Wi-Fi connection.
    • MAC filter: Make sure it’s turned off. Also set your device as allowed.
    • Channel: Try using another channel, preferably 11 or lower.
    Add your device’s MAC address to the MAC filtering table of the Wi-Fi router. Some routers require your MAC address.
    For instructions on adding MAC addresses to the MAC filtering table of the router, refer to the router user guide or contact your router manufacturer.
    To check the MAC address of your device
    • Find and tap Settings → Network & internet → Wi-Fi .
    • Tap Wi‑Fi preferences  Advanced . The MAC address is displayed in the list.
    • Perform a factory data reset. This is sometimes the best solution if your device stops functioning properly, but note that it will delete all personal content saved on the internal memory of your device. Make sure to back up data that you want to keep.
    To back up your data using a computer
    • Unlock the screen of your device and connect your device to the computer using a USB cable.
    • On the computer, select which files to back up, then copy and paste or drag and drop the files to a location on your PC.
    To back up and synchronize apps, phone settings, and call history
    • Find and tap Settings → System → Advanced → Backup.
    • Tap the switch to enable the function. Your app data, device settings, and call history will be backed up automatically.
    You can also enable backup from the settings menu in Google Drive. You can synchronize your app data, device settings, and call history automatically by logging in to the Google account used to synchronize data on your old device. When you power on your new device for the first time, log in to the Google account during the setup wizard.
    To perform a factory data reset
    To avoid permanent damage to your device, do not interrupt a factory data reset procedure.
    1. Back up any important data that is saved on the internal memory of your device to a memory card or other non-internal memory. If you have any encrypted files stored on an SD card, you should also remove the encryption to ensure you can still access them after the reset.
    2. Find and tap Settings  System  Advanced  Reset options
    3. Tap Erase all data (factory reset) → Reset phone .
    4. If required, draw your screen unlock pattern or enter your screen unlock password or PIN to continue.
    5. To confirm, tap Erase everything
        Your device does not revert to an earlier software version of Android when you perform a factory data reset.
