Multimedia messaging (MMS) on my smartphone isn't working
- Download settings for internet and MMS automatically.
To download internet and MMS settings
- Find and tap Settings > Network & internet > Internet settings .
- Tap Accept. Once the settings have been downloaded successfully, (Internet settings downloaded icon) appears in the status bar and mobile data traffic is turned on automatically.
- Check that MMS (Multimedia Messaging Service) is supported by your network operator and/or subscription.
- You can manually add internet and messaging settings on your device at any time. If necessary, contact your network operator for the required information.
To add internet and MMS settings
- Find and tap Settings > Network & internet > Mobile network .
- Dual SIM users, select a SIM card.
- Tap Advanced > Access Point Names >
(Add icon).
- Tap Name and enter a name of your choice, then tap OK.
- Tap APN and enter the access point name, then tap OK.
- Enter all other required information. If you don’t know what information is required, contact your network operator for more details.
- When you’re done, tap
(Menu icon), then tap Save.
- Check the signal strength in the status bar to make sure your smartphone is connected to a network. If the signal is weak or you have no signal, move to an open location free from obstructions, or get close to a window.
- Check the device memory to see if memory is available. If the memory is full, remove messages to free up space.
To view the memory status
- Find and tap Settings > Storage.
To delete a message
- Find and tap
(Messages icon).
- Touch and hold the conversation that you want to delete.
- Tap any other conversations that you want to delete, then tap
(Delete icon) > Delete.
To delete conversations
- Find and tap
(Messages icon).
- Check that the MMS auto-download function is enabled in your messaging settings.
To enable MMS auto-download
- Find and tap
(Messages icon).
- Tap
(Menu icon), then tap Settings > Advanced.
- Tap the switch beside Auto-download MMS to enable this function.
- Use the full number when you send a message. When you enter the country code, use "+" instead of "00".
- Turn off your device and then turn it back on. By doing this you turn off all running applications and free up memory, which sometimes automatically solves the issue.
- Update your device to ensure that you have optimal performance and the latest enhancements.
