Article ID : 00300993 / Last Modified : 21/03/2024Print
Xperia 5 V software release overview
    Welcome to the Xperia 5 V software release page.
    • Each Xperia smartphone receives security and software updates throughout its lifecycle.
    • Software release timings may vary by operator, market, region, or country.
    Latest Software Release
    Date
    Android version
    Software version
    Software improvement
    February 2024
    Android 14
    67.1.A.2.208
    • GMS package updated to Nov 2023
    • Security patch level updated. (February 1st, 2024)
    How to check the software version and how to update your Xperia smartphone
    Tip: To check your device's current software version, find and tap Settings → About phone → Build number.
    When a software update is available,  Refresh icon appears in the status bar.
    To download and install a system update from the Notification panel
    1. If you use a device with multiple users, ensure you are logged in as the owner.
    2. Drag the status bar downwards to open the Notification panel.
    3. Scroll down, select the wanted system update, tap the item, and then tap UPDATE
    4. When the download is finished, open the Notification panel again if it is closed, then tap RESTART
    Why hasn't my Xperia phone received an update yet?
    Software updates are released at different times depending on the operator, market, region, or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device. In addition, network operators and specific models.
    Previous release
    Date
    Android version
    Software version
    December 2023Introducing Xperia with Android 1467.1.A.2.182
    • Android 14 OS upgrade
    • Security patch level updated. (December 1st, 2023)
    November 2023 Android 1367.0.A.6.99
    • Security patch level updated. (November 1st, 2023)
    October 2023 Android 1367.0.A.6.75
    • Security patch level updated. (October 1st, 2023)
    September 2023
     Introducing Xperia with Android 13
    67.0.A.6.60
    • Bluetooth LE Audio improvements.
    • GMSCore and Google Dialer versions updated.
    • Security patch level updated. (September 1st, 2023)
