Article ID : 00089452 / Last Modified : 13/02/2020
The colour of the image is not correctly displayed in the camcorder
    Check the following if the color of the image is not correctly displayed.
    NOTE: The following functions may not be available on some models.
    • This may occur if NightShot or NightShot plus for high-sensitivity recording is activated.
    • Make sure the following settings are correct.
      • White Balance
      • Scene Selection
      • Picture Profile
      • Gamma Disp. Assist
    • If the Auto Back Light function is activated, the camcorder adjusts the exposure towards plus, and it may make the image displayed bright or whitish. If your camcorder has a function to change the Auto Back Light setting, change it according to the subject.
    If the issue is still unresolved, the product may need to be repaired.
