Article ID : 00076912 / Last Modified : 26/07/2019
I set the camcorder to turn off automatically, but it does not turn off
    The camcorder does not turn off automatically in the following situations even if you do not operate it for a certain period of time.
    • When the Remote commander of the Remote control Tripod is connected to the A/V Remote Connector or the Multi Terminal of the camcorder
    • When the camcorder is connected to a TV using the dedicated A/V connecting cable.
