Article ID : 00135715 / Last Modified : 27/12/2016
Depending on the SteadyShot setting, the angle of view might become narrow
    IMPORTANT: Not all models have the SteadyShot function. For details, refer to the manual supplied with the product.
    When SteadyShot is set to Active or Intelligent active, the image processing engine of the camcorder compensates the keystone distortion which stands out at the edges of the image, and the angle of view is narrower than the usual SteadyShot.
    NOTE: Depending on the model, the SteadyShot settings are different.
