Article ID : 00188129 / Last Modified : 30/03/2021Print
The camera does not focus automatically.
    Possible causes are as follows:
    • If the lens is fogged due to dust, fingerprints, etc.
      If the lens is dirty, wipe it gently with a soft cloth such as a cleaning cloth. Then, check if the issue is resolved.
      IMPORTANT: Do not expose the product to chemicals such as those in paint thinner, naphtha, alcohol, disposable wipes, insect repellent, insecticides, or sunscreen when you wipe the lens. These products may cause the lens coating to become scratched.
    • If the lens is fogged due to condensation
      Turn off the camera and leave it in a dry place away from direct sunlight. Then, wait about an hour for the moisture to evaporate, and check if the issue is resolved.
    • If the focus mode is set to manual
      If the focus mode is set to manual, switch it to the auto mode. Then, check if the camera will focus. For details, refer to the camera manual.
    • If you are trying to shoot a subject on which it is difficult to focus or under conditions in which it is difficult to focus
      Condition under which it is difficult to focus How to resolve the problem
      The subject is too close to the camera. Each lens has a minimum shooting distance. The camera will not focus unless you maintain a certain distance from the subject. If the subject is too close to the camera, move away from the subject.
      Darkened conditions such as a nighttime scene, illuminations, or fireworks Set the focus to the manual mode, and then focus on the subject.
      A subject with poor contrast, such as the sky, a beach, or a lawn
      A subject that changes constantly, such as waves or a waterfall
      A subject whose brightness is very different from its surroundings, such as the sun or a light bulb
      A subject with a continuous pattern, such as the exterior of a building
      A fast-moving subject
      If your camera is equipped with the following functions, try using them:
      • Tracking focus (Lock-on AF): The camera tracks and maintains the focus on the subject.
      • Face Priority function: When shooting human subjects, the camera focuses on detected faces with higher priority.
      Subjects in the focusing area with different focal distances
    • If the issue is not resolved by the above procedures, or none of the above conditions apply:
      There may be a malfunction in the camera parts, such as the image sensor or the monitor.
