Article ID : 00069897 / Last Modified : 06/06/2019
Can a USB hub be used when connecting a USB device to the car stereo?
    IMPORTANT: Not all car stereo receivers have USB capabilities. To see if your Sony product has the USB function described in this solution, check the specifications, which are available online in the Manual or Specifications sheet.
    Using a USB hub is not supported. Connect the USB audio device directly to the car stereo receiver or use the cable that was supplied with your audio device.
