Article ID : 00202491 / Last Modified : 24/04/2024Print
What is Netflix calibrated mode and how to turn it on or off?
    The Netflix calibrated mode on your Android TV™, or Google TV™ device allows you to experience picture quality close to a filmmaker's vision and intent. Follow the instructions below to turn it on or off according to your TV series:
    For Android TVs and Google TVs released after 2019
    Applicable Android TV/Google TV models
    • 2021 models: X95J, Z9J, X90J_X91J_X92J_X93J_X94J (50-75, 100), A90J, A80J_A83J_A84J, X91J (85) series
    • 2020 models: A9_A9S, A8_A8H, Z8H_ZH8, XH95_X95H (55, 65, 75), XH95_X95H (49, 85), XH90_X90H_X91H_XH92 series
    • 2019 models: Z9G_ZG9, A9G_AG9, XG95_X95G series
    Turn Netflix calibrated mode on or off
    1. Launch Netflix.
    2. On the supplied remote control, press the gear icon Quick Settings button.
      Settings Remote Button
    3. Select Settings.
    4. Select Display & Sound.
    5. Select Picture.
    6. Set Netflix calibrated mode to ON or OFF
    Notes:
    • If the Netflix calibrated mode is set to ON, the Picture mode settings become greyed out.
    • If you want to select other Picture mode settings, follow steps 1 - 6 above to turn off the Netflix calibrated mode.
    For A9F_AF9 and Z9F_ZF9 series (2018 models)
    1. Launch Netflix.
    2. On the supplied remote control, press the ACTION MENU button.
    3. The next step may differ depending on your TV and how the menu is displayed on the screen.
      A: Menu on the bottom of the screen, B: Menu on the top of the screen
      1. When the menu is displayed on the bottom of the screen (Quick Settings):
        1. Select Settings
        2. Select Display & Sound
        3. Select Picture
        4. Set Netflix calibrated mode to ON or OFF
      2. When the menu is displayed on the top of the screen (Action Menu)
        1. Select Picture adjustments
        2. Set Netflix calibrated mode to ON or OFF.
    Notes:
    • If you want to select other Picture mode settings, follow the steps above to turn off the Netflix calibrated mode.
