What do the colors and the flashing of the LED (On/standby indicator) on the subwoofer mean?
The table below shows what the colours of the flashing LED (On/Standby indicator) of the subwoofer mean.
Type of Flashes | Green | Orange | Red |
Lit |
Flashes |
Not applicable |
Not applicable |
Indicates a rise in temperature of the subwoofer. Follow the steps below to resolve this:
Flashes slowly | The SECURE LINK connection is in standby even when there's no signal.
Not applicable |
Flashes quickly | For HT-ST9, HT-NT3 and HT-RT5, the unit may need repair. |
Not applicable |
Not applicable |
Periodically flashes quickly |
Not applicable | The SECURE LINK connection is in progress, wait until it's established. |
Not applicable |
If you struggle with wireless connection issues
Follow these instructions if you encounter an issue with the wireless connection:
- Move the subwoofer closer to the central unit of the home theater.
- If possible, place the subwoofer where it isn't directly blocked by any furniture, walls, or metal barriers.
- Move your wireless router more than one meter (3 feet) away from the central unit, subwoofer, or sound speaker.
- If the wireless router can switch between 2.4 GHz and 5 GHz frequency bands, try the other frequency.
- For the HT-ST9, HT-ST5, HT-NT3, HT-RT5: Try switching the wireless router to the 2.4 GHz band.
- For the HT-CT780, HT-CT380, HT-NT5, HT-CT790, HT-CT390, HT-XF9000, HT-X9000F: Switch the wireless router to the 5 GHz band.
- If the wireless router has multiple channels, set it to a different channel. If the connection issue is resolved, save the setting for that channel.
- Check the router manual for details on how to change the channel.
- If the instructions aren't clear, restart the router. It may automatically select another channel when it turns back on.
