Article ID : 00081924 / Last Modified : 27/06/2017
I cannot find applications that have been added in My Apps.
    To verify if the application has been successfully installed; try searching for it using the Search menu located on the top of the Opera TV Store.
    Once found, check if the Add to my Apps option on the application detail page is available. If not, it indicates that the application has already been added.
    If the option is still available, add the application again.
