Article ID : 00058146 / Last Modified : 28/07/2019
The image blinks or appears in different colours when recording.
This may occur when recording under fluorescent lamps, sodium lamps, or mercury lamps. Adjusting the shutter speed may reduce or minimize this issue.
  • Set the shutter speed to improve the flicker phenomenon according to the region you are using the camera.
  • If you use LED lights other than for movies, there is a case where horizontal stripes appear in the image. To prevent this phenomenon, use the LED light exclusive for movies.
NOTE: Not all camcorders or cameras have the capability of manually changing the shutter speed. Refer to the operating instructions supplied with the camcorder to check for available shutter speed options.
