Article ID : 00188344 / Last Modified : 15/01/2018
How to convert RAW file to JPEG or TIFF format with the Imaging Edge software
    Download and install the Imaging Edge software on your computer to convert your RAW files to JPEG and TIFF formats.
    A detailed instructions on how to use the software to edit or convert your RAW files is available on the Imaging Edge support site.
