Article ID : 00108798 / Last Modified : 22/07/2019
What is the difference between Reset Default / Camera Settings Reset and Factory Reset / Initialize?
NOTE: The functions that can be selected differ depending on the camera.
  • Reset Default / Camera Settings Reset function
    Only reset the shooting settings of the camera to their default settings.
  • Initialize function
    Reset the settings that the Reset Default / Camera Settings Reset function does, as well as other functions like Date/Time Setup and Wi-Fi Settings. In addition, the Initialize function also deletes information stored in the camera such as registered faces, registered AF micro adjustments, file numbers, and downloaded applications.
  • Factory Reset function
    Reset all the settings that the Initialize function does, as well as AF Micro Adj.
NOTE:
  • Do not turn the camera off while resetting.
  • The camera may show a blank screen for approximately 10 seconds after performing a reset. This is a normal operation and not a malfunction on the camera.
